Hi, I have my videos on video tape (PAL I think). I would like however like to send the videos to my pals over the internet. How do I get these videos into a computer and how do I go through the conversion process? And is there a way I can record my clips from TV (this is what I do) straight into digital format or computer ready format without having to use a VCR? I reall need helpThanx.
what you want to do is called "capturing" video. if you take a look to the left of your screen, you'll see a set of green highlights that say "How To"... click on "How To: Capture" and take a look.
you will need some sort of capture device, a large amount of hard disc space, and a capturing program. me personally, I use an Aver EZ DVDMaker capture card, iuVCR for software, and I usually have at least 60Gb of space available on my hard drive.
Under the "Other" section at left, you'll see an entry for "Capture Cards" and another for "Tools". These areas supply reviews and info for capture devices and software, respectively.
Once you've captured your video, you'll want to convert it to a format that you can send easily, but that can wait until you grasp the concepts for capturing.
take a look at the guides, and when you understand some of the basics, come back with some specific questions.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
It's always funny how people try to put HUGE and BOLD in their topic (which luckily fails) as if it's the most important thing on the forum.
Start with some guides. It'll get you started.Want my help? Ask here! (not via PM!)
One on and nobody out, and the newbie steps up to the plate. Indolikaa looks around to check the location of offline, gets the sign and prepares to deliver the pitch...
Thank you so very much, let me get started and I will post more problems back.Originally Posted by housepig
Best video format and size to use to put on a webiste
By neuz in forum Newbie / General discussionsReplies: 5Last Post: 9th Dec 2010, 11:11 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 09:12 -
Help Regarding convert the large size videos of several format
By darkstonecold in forum Video ConversionReplies: 18Last Post: 3rd Sep 2009, 15:27 -
Videos to suit my phone screen size
By drwho in forum Video ConversionReplies: 2Last Post: 21st May 2009, 17:39 -
changing a videos size?
By curt1sw in forum EditingReplies: 5Last Post: 11th May 2007, 00:21
Thanx.
